Can you program the truck so it stays in the last driving mode you had when you restart it?
I wish. I haven't seen that option in there, but if it is I want it.
Does this allow you change it so you can activate the e-locker in 2wd?
You don't need Forscan for that.Can it make my fordpass work and not get a 401 error? That would be ****.
The relay for the Electronic Locking Differential is thrown from the Transfer Case Control Module. Several parameters have to be met in order for TCCM to energize the ELD coil. Evidently, in the '17 Raptor one of those parameters is set to "not 2wd". If the change can be made, its going to require changing that parameter in the TCCM.Does this allow you change it so you can activate the e-locker in 2wd?
Edit: A google search finds Forscan can access the TCCM. Whether or not the "Not 2wd" parameter is modifiable is past my pay-grade.
