Has anyone confirmed this, does it change country code?
This does not change country code
So is it safe to assume that the 2017 codes work for 2018 also?
Has anyone discovered a way with Forscan to make the seat and steering wheel move at the same time versus one then the other when easy entry/exit is active?
Also can you pull the factory door code number with Forscan?
What exactly does the DRL modification do on the Raptor
https://docs.google.com/spread...3RTMVz95730/edit#gid=815852466Guys, I may be brain dead, but where is the list of mods? I thought there was a .doc file here somewhere with all the changes, but for the life of me, I can't find it.
Sent from my SM-G950U1 using Tapatalk
