imelik1986
Estonia
Hei guys,
Can all amber lights be turned off with forscan?
Im from Estonia and by law we are not allowed to have such lighting. At least I need to turn them off for the first registration inspection.
I would highly appreciate the advice.
I only found here to turn on only the amber lights discussions not vice versa.
Brgds
Taavi
Szabo Mihaly
Romania
Hei guys,
Brgds
Taavi
How you can turn on? Mine is off and wanted on. In Romania. For the fender lights is easy. It is a connector each side of the fender. Need to look near the front tire. Just remove the plastic mud protector and will find the connector. For the 3 led lights the connector is on the top of the radiator. Need to remove the upper cover. It is a big connector but you need to cut only one wire. For the headlight yellow i don't know how to light on. I am waiting somebody to tell me how was disconnected for the first inspection.
Sent from my SM-N975F using Tapatalk
imelik1986
Estonia
Hei,
When you open or close your doors from remote then does your headlight amber leds blink at all? If not then someone have disconnected your lights from the power or have been disabled from the module. Same Im trying to find out.
Check your headlight connectors and wiring to see if any wires/pins been tampered.
Brgds
Taavi
Szabo Mihaly
Romania
Hei,
Brgds
Taavi
Yes, is lighting up when i lock/unlock the doors. I am waiting since more then 1 month this info from the Belgian dealer who disconnected but still no answer. The sales person ( is not a technical, he just ask the elecrician) says is just disconnected. But i am wondering because is lighting up. I don't really want to make changes by Forescan. Without warranty i am afraid...
Huck
Chicago Sw Burbs
What is the default setting for the fake engine noise?
My pc crashed and I lost my backup file
hedonist222
Dubai, Abu Dhabi, UAE
When enabling temperature above the gauges, what shows above the turbo (if you've selected turbo).
Right now or it shows violent temp over coolant gauge and transmission temp over transmission gauge.
When I switch over to turbo gauge, it simply says turbo over the turbo gauge.
Thanks.
Chris Thomas
Huntsville, AL
Anybody in the Huntsville, AL area knowledgeable in these modifications? I'm a new owner and am interested, but I have zero experience with Forscan. Thanks!
K223
Florida
Thanks.
You cannot set boost pressure digits above the Turbo gage. Only temps.
If you have a ‘19 up you can set
A boost/Vac gage or view the Measurements through the center stack.
