JasonVoorhees
Columbia City, In
Need a bit of help. I should've been more specific on my question. I have the turbo gauge as one of my 4 across the top sweeping gauges. How do I change that back to the transmission temp gauge?
Sent from my SM-N960U using Tapatalk
Spectragod
Dayton Ohio
Find the transmission gauge in one of the many screens available, I put mine in the first screen so I could find it, when you do find it, push and hold the “ok” button and it will change back
thatarchitect
Dallas, TX
Hey guys,
I have searched this and have not found lots of conflicting opinions but no definitive answer so I apologize if it is out there and did not see it.
I have done all the forscan mods I wanted which is amazing (thanks to all who made that possible) but am a bit unsure if I did one correctly. I did the Fake engine noise disable, or at least I think I did, which is the point of this post. I did the line for the ACM but did not do the line for the DSP because I was unclear if my truck fell in to the group of trucks that also needed to have that line changed. I have a 2019 802A Raptor if that makes a difference. Can anyone tell me definitively if I need to also change the 783-01-01 line in my DSP module as well in order to disable the fake engine noise?
Thanks in advance!
K223
Florida
Good question. I have the same truck and only did the ACM module. From what I can tell, I don’t seem to hear any fake noise.
But should DSP also be done? The notation on the common spreadsheet remarked about 2018 Lariat+ models may require this. So I left it as is for the Raptor.
thatarchitect
Dallas, TX
Sounds like we came to the same conclusion. I was just hoping that someone knew for sure because I could see it both ways.
K223
Florida
Now that you mention it, I can see that as well. I’m sure someone will chime in to assist.
Have you tried Auxiliary External Subwoofer? Someone commented that it improved the power output of the factory Kicker 8” Sub/amp. Before I try, I’d like to hear from any others that have.
Flash1034
N/W Montana
Ok. So I’m a Raptor newbie. I bought a 2019 loaded Raptor. I’d like to turn the orange leds around my headlights on as daytime running lights and turn the headlights off as daytime running lights. Which codes do I need to modify for that to happen? Much thanks.
