Mbdurham
Georgia
Awesome let me know if you find a result. Would be awesome to have! I feel like we are getting extra perks that we would otherwise have to pay extra for with this tool lol
Will do. Every other change I made worked flawlessly not sure what happened with this one
Antho
You can but you have to hit a
Button to make them dip. They won’t do it just by putting in reverse.
Antho
I d
I didn't see anything in the spreadsheet re: the transmission. Which module/settings did you adjust?
If you reset the Tcm adaptations There is a procedure to do once you reset the adaptations.
Mbdurham
Georgia
Thanks yes I read that you need to select the mirror but still no luck
Antho
Here’s a decent video. Remember you have to set the mirror to where you want it to dip, save the setting in the driver presets on the door and then when you put in reverse you have to select the mirror
You want to dip.
Mbdurham
Georgia
You want to dip.
Thank you very much! Redid everything tonight changed the C back as that was making the controls reverse. Watched this video to program and all is working correctly now!
OdinR
Norway
My Raptor has the bright white parking light all over. Cant figure out how to turn on the yellow light instead. Tried a DRL change but now my auto is gone...Can someone help me with the correct codes for the yellow markers all over but no low beams?
kpecks
Florida
I have a question about Auto-start/stop. From the factory, the truck is programmed to have the Auto stop/start enabled. I currently have mine shut off so that I don't have to hit the switch every time. But im wondering if there is a way to program it so that the default is the Auto start/stop is turned OFF when I first start the truck and if I want to enable it, like if im at a drive thru or waiting for my kids at school pick up line, I can hit the button to enable it. Does that make sense??
I think someone did a mod to the switch itself to accomplish this, back about the ’17 era (?) No idea which threat that’s buried in.
