pughde
SC
Ok I am all in with ForScan. I have made one changed after backing up all the modules.
Added temp above Engine and Transmission and it is cool. Plan on doing the following:
Lincoln Style folding mirrors on lock, Love it. Tells me my truck is locked
Enabled secure Idle (cant believe that is not factory)
Set panic alarm to two presses
I may add an option to adjust (tilt) mirrors when in reverse. But looks a little messing and may wait for more feedback.
Tonecapone
I thought about adding that "tilt in reverse"mirror option but then I figured. I have the 360 view camera so that I can see the parking lines so the mirror tilt is not really needed.
Tone
Hagasan41
Florida
Sounds like this is a great program, but am I correct in saying that no one has figured out a way to disable the auto/start/stop feature using Forscan? Or is it because it only has access to certain control units/functions on the truck?
I know with BMW the dealer can reprogram the vehicle to off as the default mode.
SeXualAVENGER
Peoria, IL
I thought about adding that "tilt in reverse"mirror option but then I figured. I have the 360 view camera so that I can see the parkibg lines so the mirror tilt is not really needed.
Tone
The mirror tilt in reverse doesn't work on our trucks.
lottp
That is incorrect. I enabled the tilt and it works great. You just have to follow the recommended programming procedure from the spreadsheet link. Also, you must have the button selected (light on) for the mirror you want to tilt when in reverse.
SeXualAVENGER
Peoria, IL
Interesting. Thanks for pointing that out. I'll have to give it another try.
shapiroeric
Longmeadow, MA
Got my license software loaded, OBD on the way. Truck comes Sat and Sunday I'll be hooking it up to make some changes. Looks pretty straight forward
pughde
SC
The Lincoln Style folding mirrors on lock worked 5 or 6 times then it stopped folding not sure if it is something I am doing. Will recheck the program options later, any advice?
