They should have made that camera like a built in go pro. Just plug your memory stick into the sync port and BAM! high def recording from the truck. It would be bought by everyone.
Now that is an AWESOME idea!!!!!
On the ordering guide rearview camera is included in the Luxury Package 55L
I believe thats correct, but I think if you get lux AND nav, then you lose the rear camera unless you get the fr/rr camera option??? For ~$500 on a $50k truck I'm getting the front camera option, whether I'll end up using it much or not, its a pretty cool new feature, and another one to help resale too.
Maybe you're right, hell if I know. I'm still going with the front camera regardless because I'm betting the truck does not have to be in 4WD Low for it to function. And even if it does, there will eventually be some kind of aftermarket product to unlock it.
Bingo, I be there will be workarounds that come out to use the front camera in other situations if it is locked out to 4low only.
Did you see where it says:
"The display from the
camera will appear on the navigation
screen on the center stack with dynamic
and static overlays to help drivers
determine where their wheels will go"
So from that I take it there will be lines of where the front tires will land, and they will move as you turn the wheels. Somewhat like the rear camera has the lines for the rear tires, but those are static only. The front will have dynamic ones that move with the steering wheel? Pretty damn cool.
