Ford Raptor wins Pickuptrucks.com Ultimate 4x4 Shootout
justvettn
GTA
The power wagon is a 2500 with front and rear solid axles with electric lockers front and back with 456 gears and $12000.00 cheaper.
---------- Post added at 07:34 PM ---------- Previous post was at 07:24 PM ----------
Hey looks like you can get one in satin black?
Cleave
Oxnard, Ca
I don't want to argue about the powerwagon, but it's $12000 cheaper for a reason, just cause everyone has been using solid axles for crawling since the stone age doesn't mean they're better, more reliable, maybe, but better, not necessarily, and according to the article, the 4.56 gears are not helping that truck, we have bigger tires, are faster 0-60, get better fuel economy, and have a better low range gearing, maybe if ram had thought more about the entire package, it would've done better, but it's just a 2500 with diffs and some shocks, it's meant to tow, despite rams effort to make it an offroader, by the way, if solid axles are good for crawling, why does everybody want to be able to disconnect their sway bars, hmm, backwards thinking right there
MagicMtnDan
Magic Mountain
The one interesting thing (to me) about the PW is the electrically dis-connectable sway bars.
It's typically done when off roading to give vehicles with sway bars more suspension travel (see Jeep Rubicon).
I like it and wish it was an option on the Raptor (HINT to FORD for the next gen Raptor).
NickPic83
Rockland County NY
just did a build online of the PW and it was $52,000 which is only 2-3k cheaper than my sticker, i added some options to try to make it optioned as much the same as possible....maybe i am wrong but i am not sure where the $12,000 cheaper came from...
Cleave
Oxnard, Ca
Sorry, that didn't come out right on my part, I wasn't criticizing the disconnectable sway bars, I was criticizing rams use of solid axles and everyone's belief that solid axles are the way to go when crawling, disconnectable sway bars are a good idea, articulation is king, one last thing, a base raptor is 43k, loaded 55k without bead locks and interior accents due to no equivalent options on the power wagon, base power wagon is 46k, loaded 53k
justvettn
GTA
The 12000 comes from the build I did on line as well and the one my dealer has with Dodge factory incentives reduced off the price compared to Raptor prices in my area, Now it would be even cheaper if I included Employee choice certificate which would give me another 7000 off and Dodge is also offering another 1500 off if you are a truck owner which the Raptor has no incentives or employee certificates that can be applied.
My brother just bought a $60,000 MSRP Ram for $43,000 that's $17,000 off.
MagicMtnDan
Magic Mountain
I didn't take your comments as criticism.
My understanding about articulation (and the fact that it is "king") is that solid axle vehicles typically have greater articulation than IFS vehicles. At least that's my understanding.
Cleave
Oxnard, Ca
I think it's cause you can get almost as much articulation while having it more heavy duty/ less likely to break, there are some pictures of a raptor with the front travel maxed out on one side and at full droop on the other side, I would love to see the solid axle front end on the power wagon manage the same amount of travel without hitting something with the axle housing, independent suspension can allow more travel with a lower center of gravity, reducing the chance of rollovers, it just can't haul as much
---------- Post added at 07:24 PM ---------- Previous post was at 07:03 PM ----------
The main problem is the availability and cost of CV axles that can take the amount of articulation needed to be a proper rock crawler, but there are CV axles out there capable of it
firematt422
Kansas City
Raptors are only that expensive if you have to have four door handles and can't heat and cool your own ass. Mine was only $43,700 with the 6.2, trailer brake... and I even treated myself to a sunroof.
MagicMtnDan
Magic Mountain
Disclaimer: This is from a Jeep forum. It may not all (or any of it) be true. BUT, I think it's interesting and worth a read on the subject of Solid Axle vs. IFS.
Originally Posted by CIJeep
Theoretically IFS should be better. With the right design the tire tread will be flat on the ground at all articulations. In reality the solid axle is more reliable, less parts, more rugged, not so spindly, and can carry quite a load.
I don't remember all the particulars, but the end result for me was decided years ago, solid axles are best. Just my 2 cents.
But then watch a fully independant long armed spindly totally tubular dune buggy with one humongous V8 virtually flying through everything and you will have second thoughts.
Originally Posted by wayland1985
IFS is actually superior in many ways. For one, the differential is up and out of the way. No Pumpkins to worry about! Also, handling characteristics on road are much better, as well as off road. Articulation-wise, I think with the right set up, you can get better articulation with an IFS than a solid axle. Look at BAJA racers. Those things have feet of articulation (mainly due to triangulation and long arms).
The biggest problem with IFS is cost. They need more parts, so they cost more. Also, more parts means more potential for breaking.
Modifying independent suspensions gets a lot more expensive too, so your lift kit will cost you MUCH more. Also, they're harder to work on. One of the biggest questions with the design of the current Mustang was Indepentent suspention or solid rear axle. Cost reasons, and the request of weekend mechanics encouraged the team to build a solid rear axle platform.
Originally Posted by Jrgunn5150
IFS is better when properly designed, look at the HMMV or the Baja trucks. Most are designed for cost and a nice ride though. Not to mention a straight axle is simple, easy to fix, hard to break, and cheap.
Like they said, IS (idependent suspension) is better all around then a solid axle. they have better on road ablities at low and high speeds. A properly tuned IS will exceed a solid axle in flex and ablities. The problem is cost. One of the main reasons a solid axle is so popular is because they are easy to lift, easy to repair, and easy to maintain. Also, one reason a lot of people don't like factory IS's is because its usally hard to disconnect the sway bar. and as almost all of us can testify to, there is a big difference in flex of a disconected and a non disconnected setup. the same goes with an IS system, a disconnected one will flex a whole lot more then a connected one.
This is one reason you see so many H1's, H3's, chevy's, etc with one wheel in the air. because they don't have the ablity to disconnect. I know there are kits out there, a buddy of mine has front disconects on his chevy S10, so it can be done, just most people don't. Baja racers usally don't even bother with a sway bar because they won't be on the road, so there is no need.
Car companies put IS's on the front and solid on the rear of trucks and mid-size SUV's so that they can still have good handling dispite their wieght, and also have that pulling power. a solid axle can be built for pulling for a far cheaper price then a IS can. Thats not to say the solid axle is better, its just cheaper. Proof that an IS can be built for towing is the H1 which has IS all around and can pull over 9000lbs.
Solid axles are strong and can take a beating naturally, but just like an IS setup, depending on the way its designed will determin how tuff it is. a Dana30 will not take the same punishment as a Dana60 will, like wise, a IFS system off a geo tracker will not take the same punisment as the IFS off a chevy 2500. The problem is, like everything else, cost. it cost more to beef up an IS system then it takes to beef up a solid axle.
The only thing a solid axle is better at then an IS, is the cost, that's it...
Link: Which is better and why? IFS vs. Solid Axle
