Ford Raptor Fuel Pump Fuse Issue
daddycreswell
Lebanon Tennessee
Repair shop called this morning. He said when the rollback dropped it off yesterday it fired right up, let it sit over night and started up this morning like it should. I told them to keep it today and just check it every now and then. No clue what happen. Guess I'll go pick it up and take it home. Very odd....
Sent from my SM-G950U using Tapatalk
BenBB
Lots of different places
Might take a look at that FPDM and connector just in case:
https://www.f150forum.com/f4/fuel-pump-driver-module-check-yours-152908/
J DAMAGE
NJ
Start rolling around under the truck, trace out all the connections, something is making a bad connection if the jarring of the flatbed loading your truck triggered something. unplug check and reconnect. If you can get an extra hand to help, and start shaking and moving wiring harnesses and check for start or not.
80sTiger
Just happened to me ... 2014 Raptor. Wouldn't turn-over completely after being parked for an hour. Towed to dealer over 150 miles. Dealer just called and said it was the fuse. Re-wiring "or it'll happen again". Ford Service guy admitted as much as a design issue, and even encouraged me to take it up with "Ford corporate". $300 fix+$300 tow.
40oz
^ sorry to hear that brother. Luckily, when it happened to me, i checked the forums, found out the the problem and stole the horn fuse long enough to get me home. Amazon has the replacement from Motorcraft for 20ish dollars. Guess they got 300 for shop hours??
J DAMAGE
NJ
$300 is way to much, at most it should only be an hr in labor plus the part , part is 12.00-20.00 depending where you purchase it, not a hard job at all.
weaponized
US
I didn't have time to read all 300 plus responses here but on a hunch I did an IR scan of my fuse Box this morning after a 20 mile drive to a job site.
I think if this had something to do with the design of the fuse Box that every vehicle made would show a heat signature at fuse 27. Mine did not. This leads me to think that this fix at the fuse Box may be nothing more than a band-aid.
I don't think that fuse should be getting hot in the 1st place, and on those vehicles that are getting hot... Something is wrong somewhere else that's causing it to draw too much amperage.
It's rare that I use my equipment for automotive applications but I thought what the hell. I do use it for commercial and residential electrical systems quite often. If this were an AC power system I could see a loose wire or bad breaker causing such an overheat but I'm skeptical of a design issue here because it would be more widespread. More importantly...it would be unlikely to be the same breaker on every vehicle since all of those small breaker sockets share the same design.
The hottest thing in this image are the 2 relays at the top at 139゚. That might be a little bit hotter than the water heater circuit breaker in your house for an electric water heater that's operating. My breaker 27 has virtually no heat signature. This is at idle after a 20 mile run down the highway. I have about 80000 miles on my 20142805c4c47ebe34306274294620ae63c4.jpg
Sent from my SM-G965U using Tapatalk
