Installed on a 2019 Raptor.
Part # KN1Z-19A361-A
Came with the module, 6 zip ties, a jumper, some stickers, and manual.
As a normal person would do, I opened up a beer, didn't read the manual, and went to work on it. I didn't order the bajamod thing, figure if this doesn't work, i can always get it.
Harness was easy after reading all of the posts, pretty much self explanitory. Figuring out where to zip tie it was more challenging. Anyway, I saw a few holes on the L side above the kick panel. You can see in the attached pictures after I put it in. Maybe should have taken some pre pictures. I was able to tighten up the zip ties pretty well. Locked the car, and went away for 15 minutes. Came back, hit the b pillar and the Alarm went off. Didn't get a warning honk.
Didn't need the jumper and kept the sensitivity setting as it came from ford. May try and adjust sensitivity to see if I can get it to give a warning.
If you are going the zip tie method, I'd put on all of the zip ties through the holes before you tighten any of them. Also put in the top 2 first as you have some more mobility.
