Ford Pass Features 17 vs 18 vs 19
Wfo
Syracuse
Thanks for checking! Mine is a 9/11/18 build, metal pan, but the psi doesn't read out on the FordPass app ver. 2.6.0. I also did the uninstall/install on my Android phone.
Curious...do you have a iPhone or Android?
Also what version of the Sync 3.** software & build number is loaded on your Raptor? (Settings/General/About Sync)
Sent from my SM-N960U using Tapatalk
I’m sorry, the app doesn’t show psi only low warning. The truck display shows psi.
aalonso
Build date is 9/21/18. No shark fin antenna. I have metal oil pan and frozen lock fix”that doesn’t work”
The best fix for the freezing latch is to use WD40 White Lithium Grease.. I have been using it on my old GEN1, and continue to use it on my GEN2 and never had a freezing latch even after washing the truck with 32F temps.. all that you need to do is to spray all latches from the outside as you pull on the latch handle and inside of the mechanism thru the inner locking mechanism in the side of each door.. spray enough until it overflows!! That is the best and true reliable fix!
Helopilot
Northern MN
Known bug on newest version of the app. Try logging out first; that fixed it for me. If that fails, then you can uninstall and reinstall.
BTW, 17s have location too.
Thanks for the tip! I lost location on the app about a month ago and was getting kind of pissed about it (not enough to actually do something about it though). I logged off and when I logged back on the location was working. You’ve got a future in I.T., Maybe we can get your truck wrapped in “Raptor Geek Squad” colors!
All kidding aside, thanks again for the tip.
1roadking
On my 2018 it showed a picture of my truck color and everything, my 2019 there is no pic. Is that normal?
jzweedyk
Moab/Winter Travel/Summer Travel
On the Ford Pass with my 19, it shows the truck with the decals and color correct. I think I remember building it on the Ford website when I was waiting for the truck to be built. Whenever I logged in to see an update it showed the correct truck.
