Ford gets ready to unveil the aluminum F-150
skyscraper
with as much testing that goes on with these trucks, I dont see them releasing an aluminum truck that will fail.
SaintsFan
Louisiana
Probably true, but then again a lot of people didn't see them releasing an Explorer equipped with defective tires that caused a major rollover epidemic.
Reptar
Jersey
Yea, apparently since 2004 on all the F150 hoods. Didn't realize that.
That makes perfect sense!
Every single 99-03 f150 and expedition, and 04 heritage/Lightning had an aluminum hood. I believe even the 97-99 did too.
Sent from my SM-P600 using Tapatalk
MagicMtnDan
Magic Mountain
Here it is guys!!! So, are you glad you have the Raptor you have now or will you change to this lighter, better mpg version? I will be ready to change after its out a year or so to see how if stays together...
Ford gets ready to unveil the aluminum F-150 - Jan. 2, 2014
Hey, that looks a lot like the Ford Atlas concept truck that's been posted on this website for months. Who knew it would be aluminum-ized and would weigh as much as 700 pounds less than the current F150?
Good analogy! What did Ford's Explorer have to do with Firestone's tires being defective?
sabumaru
The Netherlands
Rap
Why not
It just has to be done more expensively
Alluminum to chromoly should benpossible for an expert welder
And the cage should pass thrue the body work and welded to the frame bars
Imo not impossible
Just more €€€€ needed
H
Hockster
My 45ft Bluewater Party
Winchester, Va
Ya the frame will still all be steel... so it will pose no problem as long as you dont wan tto use the body structure and that aint used anyways
justvettn
GTA
It was no epidemic, I watched a program about it where a test team drove the Explorer at different speeds, purposely blew out a tire, purposely swerved and swerved the SUV and could not get the thing to roll over, all while being on the road of course.
sabumaru
The Netherlands
Sounds like they tried that where the first model A mercedes failed
That thing fell over after 3 turns
They fixed it
Usualy something to do with suspension and swaybar setup
