Ford gets ready to unveil the aluminum F-150
The Car Stereo Company
here, on frf
probably not the best idea for a raptor in aluminium for all the ones who have or will bend their frames, its just that much more expensive to fix, or one step closer to a total.
sabumaru
The Netherlands
Not sure
Even tough its less strong
I think you could reach the same strength
Just by the right bracing setup
Without increasing wait that much
justvettn
GTA
The frame will not be aluminum. I dont see it being a bad thing, Land Rover has been building aluminum offroaders for a long time. Dodge has an aluminum hood on the Ram and apparently ford does too. I know of aluminum panels and aluminum cars going back to the early 60's and people love them for that reason.
sabumaru
The Netherlands
Would also lower center of gravity then
I guess
So that is also a good thing
If they make a raptor
But with the succes of the raptor
Why wouldn't they ??
Deleted member 12951
Guest
Doesn't the raptor have some fiberglass on it anyways, doesn't that reduce some weight? Not sure if 750lbs will be lost.
tbone
the bay norcal
If it has the body of aluminum but still a steal boxed frame without a hole in it over the bump stop! and if the raptor continues and has the same if not more travel and the same or better shocks in theory it should perform better off road But I'd buy a new one to keep as a street queen and my 2010 as an off road only
