First time audio install
delliott
delliott
Granite Bay, CA
Use RCA, not optical with the ZEN. That way you receive the highest resolution
Good to know… I’m almost done setting up the amp rack, running wires on the back to keep the front cleaner. Probably finish up the rack tomorrow.
Next weekend:
Sound Deadening
Block off plates
Install door speakers
Install tweeters and run wires
DSP base tune
SoundsGoodStereo
F-Series Stereo Specialist
Nashville, TN
Next weekend:
Sound Deadening
Block off plates
DSP base tune
Couldn’t finish today, didn’t want to rush the wires on the back, but it’s all coming together View attachment 481666
Looking good!! Remember to attcha the Power/Ground of the ZEN to your distro blocks, do not let it use the factory power/ground that normally feeds the factory amplifier
delliott
delliott
Granite Bay, CA
I ran a ground all the way to the battery just for that. From the distribution block I just run a ground wire to this "black" wire and positive wire to this "Yellow" wire correct?
(cutting them both from the harness and just having these two new lines for power and ground instead).power and ground zen.jpg
SoundsGoodStereo
Nashville, TN
(cutting them both from the harness and just having these two new lines for power and ground instead).View attachment 481776
You got it!! Awesome job on your research
delliott
delliott
Granite Bay, CA
No thank you! When doing my research I found post from you guys all the way back in 2021 on other F150 pages talking about the importance of the ground all the way from the battery, and read the ZEN A2B Installation manual to figure out the correct wires to tap into.
greatone99
ma
be careful if aim the blocks that way the jack gets in the way, sounds good, hang's them so they point up, the first time I did is on the left no jack, second one is the one I bought from them.
