First Oil Change
AGBoston
I saw a thread on here about 1st oil change. Then read a long debate on type of oil to use 1st oil swap. I plan on flushing out the OEM oil at about 800 miles. Am I switching to synthetic at that point or do I replace with OEM again for the "seating" process? I plan on hammering this truck after 1k miles.
If this is a painstakingly novice question I apologize. Coming from the 6.7 side. I haven't had a gasser that i care about in a long time.
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Why are you changing your oil at 800 miles? Truck barely has dust on it by then.
Azholley
Peoria, Arizona
1st swap should be on the early side no? 800-1500 mile.
I think 800 is a little excessive. I'd do one in the lines of 3-5k. When I called a ford tech they said 5k. I believe the manual says 5k too I'll have to check later. I'm at 4200 oil still looks good and levels are good. A lot of people will have opinions on this though so just do what you think. I can assure you I don't drive my truck lightly lol.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
Full synthetic is good from day 1. I am with you on the first change being early. I do all my new vehicles at 500 miles and then at 3000 miles going forward. Excessive, sure. Piece of mind for me.
gryGhst17
You'll get a different answer from almost everyone. I've always done 3k on a new or rebuild.
---------- Post added at 04:19 PM ---------- Previous post was at 04:18 PM ----------
Thought being the motor needs the material in the oil to complete the break in
dlbb
so cal
lol i intend to treat this truck just like my last new truck. a 14 eb lariat hd. i changed the oil around 1500 miles to get full synthetic in it. then every 5k-10k depending on when the change oil notice came on. when i quit driving as much i changed it once a year regardless of the 2-5k miles i put on it. also only ran 91 oct. i had no issues or any intention of getting this random upgrade to a raptor.
