- Joined
- Mar 15, 2013
- Posts
- 3,210
- Reaction score
- 2,342
@TheWolf, thanks for the wire up on the black matte. Probably warrants its own thread. As you can see, it's not as easy as running a wash pad over it. It takes some care and thought into your cleaning routine. The purpose of the black matte is NOT to be shiny, how ever you want it dark and full of depth. I've used the detail spray on mine and it looks good afterwards. I haven't used the H2O gg yet, sounds like that was a chore.
I suggest that you also add to your write up the importance of choosing products that have a neutral ph balance. Harsh cleaners will damage the wrap. I had a dealer clean mine, and it left the wrap in bad shape. I didn't realize it at the time, and they certainly didn't do it on purpose.
@Yukon Joe![]()
www.runraptorrun.com
Good points Joe!
A neutral pH shampoo like Adam's Car Wash Shampoo is very important, since this is the product that will be used often to clean the vinyl.
Some more tips:
Never wash, clean or apply products to vinyl when it is hot to the touch. Allow the vinyl to cool down and work in the shade or a garage.
Do not use abrasive polishes, clay bar, or machine polish vinyl.
When hand polishing with Revive, be careful along the edges to prevent build-up. Apply the product along the edges, not back-and-forth across the edges.
When trying to clean off visible stains or residue that are not removed by washing, start with the least aggressive method first: Waterless Wash wipe-down after a wash, Revive Hand Polish, or Brilliant Glaze. While the most stubborn stains might required diluted All Purpose Cleaner or diluted isopropyl alcohol, these two products should only be used as a last resort, since they can both cause damage if not done properly.
And yes, you are correct, it takes some work and technique to apply the H2O Guard & Gloss. Another easier option for protection is VRT Dressing, but since it is water-based, it will only last a few washes or rains, while the H2O Guard & Gloss will provide about two months of protection.
I will add these tips to the above write-up that I did under my own account.
Thanks
Dan
