Fire Extinguishers?
t_j
Chicago, IL
I have a zip tie attached to one of my Halon bottles; should there be a fire in the cap I pull the pin and hold back the trigger with the zip tie and get out.
I also have two dry chemical extinguishers in the bed of the truck.
Thats a good option!! I would still rather have something I can be stuck in the cab with and use. Maybe I will but a second extinguisher under the front of the passenger seat that is CO2.
Jimbo
Mad Frog Mattis
IL
Hope you grab the right one in the time of need...
t_j
Chicago, IL
Anything I but in the cab will be safe for use while in it! Not putting halon on my truck at all that shit is dangerous, especially if someone that does not know what it is uses it while you are stuck.
Jimbo
Mad Frog Mattis
IL
Unless you're with @caverndiver and he has his SCUBA shit in the cab :ROFLJest:
The Macf
Vegas
Didn't you put the Halguard's in your seats?
Deleted member 12951
Guest
Can someone post up a link of a good CO2 tank that they would recommend?
PropDr
Eugene, Oregon
Both, CO2 or Halon work the same: displacing oxygen, you just need more CO2 to have the same effect as Halon.
But CO2 can also cool a six-pack of beer very quickly :)
---------- Post added at 07:59 AM ---------- Previous post was at 07:52 AM ----------
No, I attached the halguards to the front of my seats, but CO2's in the seats would be fantastic in the seats to cool them down during a hot day in the desert LOL (Dry ice)
t_j
Chicago, IL
Yeah, CO2 is not heavier than air though so you can recover by opening the window. Halon on the other hand will fill your lungs from the bottom up displacing the air and suffocating you.
