Oh yeah always too much gear I will definitely keep track I'm very particular about these things thanks and I'll keep you guys posted.I’m assuming that, like us, you’ll have some gear you take along to set up camp. If that’s the case then you have that 450lbs (4-wheeler + pop-up tongue weight) plus what’s in the bed. That adds up quickly if you have stuff like tools, a gas can, generator, grille, chair, table, etc). Make a list of that stuff and estimate the weight of each item. You’ll be surprised how quick it adds up. My gues is that you’ll find you have an extra 200-300 lbs of gear.
Good news is that the airshock setup is probably overkill for your setup. BUT, I’d definitely get the deaver +3’s. That will really help.
As for the brakes, I just checked the specs of your trailer and it shows you have electric drum brakes. You should be just fine. I have the stock brakes and although they’re not the best, with the brake controller set with the right amount of gain, the trailer will handle the braking of the trailer and the truck will brake as it always does (more or less).
So again, Deaver +3’s and you’ll be happy. They also make the ride of the truck a lot smoother than stock so you really can’t go wrong.
Sent from my SM-T813 using Tapatalk
