Finally a good use for the skinny tray between the shifter and the cup holders.
K223
Florida
Raptorrunner2019
Wewahitchka
I can’t quite remember. I just remember hearing him saying it and the feeling of I can’t believe somebody would vote for this clown.
And scared that he could actually make it that far... now he is front runner for a party. Incredible times
I think he also mentioned, all you need is a shotgun (pump obviously) and just the sound of you racking it load a shell is enough to scare away anyone.
It certainly makes a statement!
DreadPirateRaptor
DreadPirateRaptor
FL
I think he also mentioned, all you need is a shotgun (pump obviously) and just the sound of you racking it load a shell is enough to scare away anyone...
We had this very convo at the shoot house.
Me personally “ Oh he’s reloading, push on his position “
Oldfart
Where can I get that extension?
Or do you mean you made made it so it's a one off
You can buy the extension, then you modify a 33 round Glock mag to attach it to. It's not hard, it just takes time to chamfer the edges and corners of the mag and modify the follower so it doesn't hang where they join together. It works really well with 115 grain, the follower can hang with heavier rounds. A few of us are having the same experience, still trying to figure out why. It comes in a 47 extension and a 57. The company is MBX. They make a lot of trick stuff.
https://www.mbxextreme.com/index.php?page=Firearm_Accessories_Extensions
Sure, It's a JRC, Just Right Carbine, with a 12 MOA C-More Railway sight. If the mag was a little longer I could use it as a rest! Great gun, but you have to keep it super clean if you want it to run 100%. That is a pain because it doesn't break open like an AR. You have to pull the buffer tube and everything slides out the rear.
America! I love it!!
do you replace the spring in the mag? GG 57 rounders do work most of the time with a regular 30 rounds spring but one was a bit more problematic. I ended up tacking part of a spring from a bad mag onto each 57 rounder. Now the both run like champs.
Oldfart
Yes, you replace the spring with one that MBX gives you with the extension. They run faultlessly with 115's, with 124's and up, it's a coin toss on how they will run.
