Fault code advice
darinz
New Zealand
Hi Team. My truck has gone into limp mode several times recently and solved one problem which was a broken wire to the MAP sensor which cleared those codes but after driving it for a few days it went into limp again and the codes are..
P0237:26 Turbo Charger Boost sensor A Circuit Low
P025E:24 Turbo Boost Sensor A Intermittent / Erratic.
Along with this it has a very lumpy idle almost like having a big cam. (only when Tool warning is up though).
I have also noticed a small amount of oil smoke out the exhuast so guessing it all points to a turbo problem but any other things I should look at before ripping turbos off?
Also after about 30 minutes turned off the fault clears and it drives normally and can for over a week before doing it again.
FYI 2017 extra cab.
20Ecoboost17
North Augusta, SC
Disconnect the sensor and check for water intrusion/corrosion in the connector and sensor. This is just a quick test since it's not easy diagnosing an electrical concern without actually being there in person. Screenshot (175).png
darinz
New Zealand
Thanks. I've pull both MAP sensors and cleaned them and 1 they weren't really very dirty and 2 the connections all looked OK. Given the cost of new MAP sensors, I think I'll just replace them both and see if that changes anything. Pretty much an elimination path now i think....unless any other ideas?
