darinz
Hi Team. My truck has gone into limp mode several times recently and solved one problem which was a broken wire to the MAP sensor which cleared those codes but after driving it for a few days it went into limp again and the codes are..
P0237:26 Turbo Charger Boost sensor A Circuit Low
P025E:24 Turbo Boost Sensor A Intermittent / Erratic.
Along with this it has a very lumpy idle almost like having a big cam. (only when Tool warning is up though).
I have also noticed a small amount of oil smoke out the exhuast so guessing it all points to a turbo problem but any other things I should look at before ripping turbos off?
Also after about 30 minutes turned off the fault clears and it drives normally and can for over a week before doing it again.
FYI 2017 extra cab.
FYI 2017 extra cab.
