Falken Wildpeak tires true 35's
Yukon Joe
Trafford, PA
I think you'll get better longevity out of the Wildpeaks and they'll be a smoother/quieter on road ride. Duratracs would probably be better for mud due to their larger lugs. I will say the Duratracs are a "meaner" looking tire.
I agree.... that's why I'm going to get both. Lol...
I'm going with the Duratracs for this winter. Then after my other set of stock tires wear out, I'll get the wildpeaks.
Got a good price on the GY DT, $314 /tire mounted and balanced.
Yukon Joe
www.RUNRAPTORRUN.com
Aaron
Meme Corps Commandant
WA
You'll like em Joe, they're a good tire. I haven't tried them in the winter, but as good as they are at everything else from sand to mud and everything else, I'm sure they'll be amazing.
I can't wait to get my Wildpeak 37's this spring. Tired of my truck looking tiny in the pics with everyone else's (especially Tizz's truck)
Flying_Raptor
Dallas, TX
Toyo open country M/T for the win.. That's my no brainer.....don't get me wrong those tires look great but I'd like to see how they perform in the mud/wet conditions.
And the tread lasts FOREVER compared to the BFs and other brand tires I've ever had.
Flying_Raptor
Dallas, TX
I just wish the toyos weren't so heavy
If u got some light weight wheels like the methods I don't see it really posing to much of a problem with the added weight. Compared to other tires. If I remember correctly each 1lb of rotational mass is the equivalent of like only 10 lbs of dry weight. Heck if you really want to do the math here's the formula lol.
"I've heard that 10:1 bit of wisdom before, but I don't think it stands up to scrutiny. It is absolutely true that a pound saved in the wheel or tire is worth more than a pound saved somewhere else, but not a factor of 10 more. I did a "back of the envelope" calculation using basic physics principles, and what I find is that a 1 pound savings in wheel and/or tire weight is equaivalent to about a 1.5 pound savings in the non-rotating weight of the car. What I did was compare the power needed to accelerate a 1 pound mass in a straight line versus the power needed to increase the rotational veocity of a wheel with a 1 pound mass concentrated at the rim an equivalent amount.
Here's the anaysis. To keep the math simple, let's assume the following:
1. The diameter of the wheel is 18", or in other words the radius of the wheel (r) is 9 inches, or 3/4 ft.
2. The radius of the tire (R) is one foot.
3. All the weight savings for a 1 pound reduction in wheel weight is concentrated at the outer edge of the rim - that is, 3/4 ft from the center. This is a bit unrealistic, but is the most favorable assumption with respect to trying to show the advantage of reducing rotating mass.
The instantaneous power needed to linearly accelerate a given mass (m) is given by P(linear) = m*a*v, where a = the acceleration, v is the instantaneous velocity.
The power needed to increase the rotational velocity of a wheel is P(rotation) = I*alpha*omega, where I = rotational moment of inertia of the wheel & tire, alpha is the rotational acceleration (in radians per sec squared), and omega is the instantaneous rotational velocity (in radians/sec). Alpha is related to the linear acceleration of the car by a = alpha*R, and omega is related to the car's velocity by v = omega*R. So the power required for rotational acceleration can be expressed in terms of a and v by: P=Iav/R^3. As for the value of I: for a 1 pound mass concentrated at a distance r from the center of rotation, I = mr^2. Putting it together: P(rotation) = I*alpha*omega = mr^2av/R^3. Since r = 3/4 ft and R = 1 ft, that means you have P(rotation) = 9/16 * mav.
Note that P(rotation) is 9/16 of the amount of P(linear). Now if you can save that 1 pound of mass in the wheel you save on the power needed to both spin the wheel up to speed and to acelerate on down the road, so the total savings in power because of the lighter wheel is (1+9/16)*mav, or just more than one and a half times the power savings if the weight was some place other than the wheel. So while saving a pound in the wheel is definitely more advantageous than saving a pound of weight in the rest of the car, it's no more than about 50% better (not 900% better as claimed).
Of course this says nothing about the other improvements that come about from a ligher unsprung weight - namely faster damping of vibrations and less transfer of energy from the wheel into the car when you hit a bump."
Maxx2893
Rock and Roll Offroad
Burleson, TX
I've been a huge fan of my Toyo Open Country A/T's. Have almost 40k miles in them. The 35x12.50r17's are an "extreme" size. So they have deeper lugs and more side lug than the smaller sizes.
Madcowranch
Genetically Modified
OK
Maxx, I didn't know you had the AT's. That's what I'm looking at for my next set.
Maxx2893
Burleson, TX
They've been awesome so far. If you haven't bought new ones by TRR, check em out.
Are they the newer AT2's?
yeah the AT 2's. If you go to Toyo's website they show some variations. The 35's are considered an extreme size so they gave them deeper and wider tread and more aggressive side lugs. Toyo debuted them on my truck at a truck show in Dallas. The 35x12.50r17's are only 70lbs too.
http://toyotires.com/tire/pattern/open-country-at-ii-on-off-road-all-terrain-tires
Click on this picture on that link and it'll show and explain a little more.
