Fabtech 4" Suspension Lift System for 2017-2018 F-150 Raptors.
If you’re looking to add 37” tall tires to your 2017-2018 F-150 Raptor, but your rugged pick-up just doesn’t have the suspension height required to get there then this Fabtech K2263 4” Suspension Lift System is just for you. This 4” Suspension Lift System from Fabtech is specifically designed to lift your rugged F-150 Raptor enough to comfortably fit those larger, aftermarket tires you’re yearning for.
Features and Benefits:
- Heavy-duty ductile iron steering knuckles
- 1/4” thick steel crossmembers
- 1/4” thick steel skid plate
- Super stout front and rear shock extensions
- Increases suspension height
- Retains factory SVT control arms
- Retains Fox Shox
- Allows for use of 37” tires
- Detailed Installation Instructions
Featuring heavy-duty ductile iron steering knuckles, this lift system is designed to handle 37” tall tires with the vehicle’s electronic stability control (ESC) and traction control. This lift system from Fabtech will avoid the steering and brake issues on the factory Ford steering knuckles typically caused by installing bigger tires on your pick-up. Super stout front and rear shock extensions are utilized to retain the factory Fox Shox. To keep the front CV angles proper with the new ride height the front differential is relocated and comes with a 1/4" thick steel skid plate for protection.
Recommended Tire and Wheel Sizes:
- Use 37/12.50R18 tires with 18x9 wheels with 5" BS with minor trimming
- Use 37/12.50R20 tires with 20x9 wheels with 5" BS with minor trimming
Please Note: Cannot use OEM wheels and tires with this lift kit.
Fabtech's development capabilities are second to none with over 20 years of experience in aftermarket suspension design. State of the art software, fabrication equipment along with their seasoned engineers and fabricators allow the company to develop products that are constantly on the cutting edge. Fabtech designs continue to lead the market to this day.
Order this Fabtech K2263 4" Suspension Lift System for your brand-new 2017-2018 F-150 Raptor today from CJ Pony Parts.
- Retains Fox Shox
