F@#$ing Fuses
bfr
Mountain West
Clam man...
So this is not the style you are looking for?
swoop1156
USA
No, he is looking for the little box-styled ones to replace amperage for the AUX switches.
bfr
Mountain West
This picture has them in pretty much their actual size if that helps.
Those are the 5, 10 and 15 amp versions.
bfr
Mountain West
Those are known as Low Profile JCASE 58V Automotive Cartridge Fuses.
Littelfuse makes them starting at 20 amp
30 Amp Aux 1 & 2 (Mouser Electronics link)
The Aux 3 and Aux 4 are the earlier posted 15A and 10A Mini ATM Low Profile fuses.
bfr
Mountain West
Looks like the Cooper Bussmann equivalent is called a Low-Profile FMX Female Maxi Fuse.
Available here
or here.
Ignore the 1" length in the Grainger description as they list the FMX and FMX low-profile as the same dimension.
Should note that these Cooper Bussmann's are rated to 32V instead of 58V.
Another 58V rated version is from Waytek.
None of these I've posted are identical to the OEM...which has little ridges on the sides. But I'm certain they would all work.
Can't find that exact OEM one.
Did notice that almost all of the fuses in my fuse box were not completely seated when installed at Ford.
Good luck Clamup.
CLAMUP
CLAMUP
Got it, type FMX AND FMX LOW PROFILE, these are the little bastards- thank's SilverBolt/bfr/BOJANGLES
PEZ
Morgantown, PA
I just had to buy one of these because my trailer brake and turn signals weren't working, $7 at NAPPA for one fuse!!!
