External Air Temperature Sensor Location
spot
Mine does the same thing. It was about 37 degrees out and when stopped at a light it showed 53.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
I found a pic of the temp sensor. Above the horn and to the left it's attached to the core support right in front of the radiator. First one I have seen that does not have a heat shield to prevent the warm air from the radiator affecting the temp reading. This either needs a heat shield or to be moved over away from the radiator.
