Extended Warranty Thoughts
highpowernut
I'm about to hit 60k miles and have the factory warranty expire. What mileage did you guys have when you purchased those plans?
I just extended my warranty. I'm currently at 94k.
Got it extended by searching the forum, found Troy Dietrich @ ford of greenfield MA.
I live in Arizona, and the process was quick and easy. I was quoted by several dealers several hundred dollars more.
I went ahead, and got the warranty on the phone. Saved money and got what I needed.
Thanks
Troy
john.rubicon.54
Thanks
Troy
What mileage will you now be covered to? I'm at 57k and I'll reach 100k by this time next year. It would be great if I could find warranty after that.
highpowernut
Extended to 129k.
Extend it now! I'll pm Troy's info cost less if you do before hitting mileage points .
LastLight
Navarre Florida
I just got these prices from Troy on a Raptor still within Factory warranty just a couple days ago as I am looking for one on another Raptor now;
PremiumCARE
4 yr / 75K - $804.00
5 yr / 75K - $859.00
5 yr / 100K - $1149.00
6 yr / 75K - $964.00
6 yr / 100K - $1249.00
6 yr / 150K - $2409.00
7 yr / 60K - $944.00
7 yr / 75K - $1254.00
7 yr / 100K - $1379.00
7 yr / 125K - $1939.00
7 yr / 150K - $2859.00
8 yr / 75K - $1429.00
8 yr / 100K - $1579.00
8 yr / 125K - $2229.00
8 yr / 150K - $3294.00
All are with the standard $100 deductible and do not include 1st day,
enhanced rental, or int/ext lighting option.
Baron138
Monmouth County N.J.
I did the extended and it more than paid for its self already. Under the extended, they replaced the rear window for the defroster issue that they have. They also replaced all 4 bead lock wheels for the finish that was lifting off with corrosion. Those two things alone that they covered more than paid for the ESP.
RaptorEnthusiast
Pardon the side question here, but I'm considering purchasing a 5-star tuner for my 2013 SCREW. Would a tuner void my extended warranty in any way?
Thanks
David
GMAN62465
Connecticut
Can you PM me Troys info!
Here you go
FD-Warranty.com
1 Main Street
Greenfield, MA 01301
t. 413-772-0989
Contact - Troy Dietrich
www.fd-warranty.com
I used Troy as well! Great guy!!
GMAN
Sent from my SAMSUNG-SM-N930A using Tapatalk
---------- Post added at 07:05 PM ---------- Previous post was at 07:04 PM ----------
Here you go
FD-Warranty.com
1 Main Street
t. 413-772-0989
www.fd-warranty.com
Factory Discount Warranty
GMAN
