Extended Engine Cranking when starting
asg0524
NY
I’m the same. I’ve also noticed it more when the tank is around 3/4 full or more which is what led my tech to believe it may be a similar issue to the 7.3s
Any word yet?
_M_
Any word yet?
Got the fuel pump replaced last week. Been waiting for more cycles to give a full report but so far so good.
They also seemingly took care of my exhaust rattle. Replaced a big piece of the exhaust including catalytic converter
nd3
YOU ARE NOT SUPPOSED TO SAY RETARDED ANYMORE! COME ON, MAN!!!
I think my timing is retarded.. :bleh:
Retarded timing can be defined as changing the timing so that fuel ignition happens later than the manufacturer's specified time. For example, if the timing specified by the manufacturer was set at 12 degrees BTDC initially and adjusted to 11 degrees BTDC, it would be referred to as retarded.
MeFryRice
Marietta, Ga
I just took delivery of my 2024 R today. Noticed the extended crank as I first leave the dealership. It also happened again as I went to grab dinner for the family. I’m glad to see other people are dealing with a similar issue.
signalbobby
So definitely still persisting with all 5.2 and its tune or fuel pump or whatnot.
Curious to when the recall will come out for this.
BadWRP
My truck is currently at the dealership for this issue. I've provided them my video and they still have no answer.
signalbobby
My dealership kept it for 3 days and said "could not reproduce" and sent me packing. They "pulled" logs and diags and found nothing.
I just doubt they really did anything unfortunately because it doesnt throw a CEL when it takes forever to start.
It sounds like there no cylinder pressure when it cranks like that.
