Exhaust Tips
j3ff
St Louis
Absolutely. Originally I had on my stock exhaust and then with Corsa system.
what is the stock OD of the exhaust pipe? (factory not, CORSA) i'd love to install the CORSA tips, but wasn't sure of the stock pipe size. you mentioned using an adapter?
aalonso
“Manicured” carbon fiber Borla exhaust tips!!
Kirby Lastinger
Lakeland, FL
I had an exhaust shop cut my factory tips off and install the corsa tips. Then a month or so later I bought a Corsa exhaust and the tips fit perfectly on it of course.
MnFlyer
MN
Has anyone actually cut the stock tips off and replaced them with something else? Or is the only real option to replace that part Of the exhaust piping?
Thinking I might try sanding them down a little and taping off the area and just paint them with some matte black high temp paint?
waveslayer
CA
I wack mine all the time on trails...
Who makes a good exhaust exit that dumps it right by the axle or side exit?
I'd prefer it to dump straight down, that way I have some better departure angles
My wife thinks I only have 3 guns
V
vazo
I'm thinking the same thing.
Looks like replacing the tips with a gunmetal tip from Corsa is around $500 based on what I found on eBay.
If I'm gonna spend that on tips I'd rather add difference and replace the entire exhaust.
But that's another post ... Lol
Sent from my SM-G960W using Tapatalk
SL75
Toledo
Here is what you can do with removing these.
