Fusco0520
- Joined
- Jan 29, 2017
- Posts
- 171
- Reaction score
- 80
did they tell you what actual code it threw?
did you removed the two air silencer rings/ tornado pieces from the intake pipes?
When i installed my Roush CAI, and removed these, it threw the PO4DB code ( drop in crank case vent pressure) Roush said this happens if you removed the silencer rings, changes the amount of suction on the crank case vent lines, but should be mechanically fine. Happened once after about 400 miles, then again after another 1000 miles, both times when i started it up and got on the throttle pretty quick after warm up.
both times got the same generic 'engine misfire' message from Ford PASS app.
So should I put the rings back in then? Cause I removed mine and I get that message also after getting on the throttle hard after the truck has just warmed up.
