EMERGENCY: Any Raptor Mechs in Moab for Service
WillieFlo
Houston
Halfway through White Rim Trail, I’ve lost lower A-arm bolt!!!!! Stuck out here. Any one have number to OR Recovery?!? Need it ASAP!! Thanks!!
BroncoAZ
Cape Cod, MA
Can you stick a socket extension, large screwdriver, or something else in there to get off the trail?
I’d be sending a search party back down the trail to find the bolt.
WillieFlo
WillieFlo
Houston
Thx guys. San Juan sending a deputy to get us and Nations will come get the truck tomorrow.
WillieFlo
WillieFlo
Houston
Just had camber adjustments bolts installed before trip for an alignment. That’s what came out. Ran a short while with it out to get to safer level ground. That caused me to break sway bar end link, which punctured CV Boot. Still drivable if I can get a bolt back in there? And sway bar link removed?
CoronaRaptor
CANADA
You can drive without the sway bar link, I would unbolt the other side while you are under there. Did you do the camber bolts yourself or a shop?
