Eibachs on 2020
Ron Lanza
Newnan, GA
If you keep the stock wheel size with the Eibach springs would you suggest doing the +2 or +3 Deavers? Not sure if the +3 would be too exaggerated rake or not... Checking out install videos and this looks easier than the fronts.
And I guess as a less expensive even easier install giving the same appearance (not the same ride) would be 3" block kit.
Would a block kit make it ride harder or softer ?
bowhun2r
Pittsburgh
Similar to a front spacer lift... it's an inexpensive way to aesthetically lift the truck. There are better ways to achieve height with improved ride. These options come with a higher price tag. The block lift is pretty cheap compared to new rear leaf pack. It may make sense just to try the larger block and see if the ride is ok for you. Else it looks like the Deavers are the best choice to raise the rear and accomplish a better ride/handling experience.
