Eibach Pro-lift springs installed with pics and comments
Nick@Apollo-Optics
is there a reason why the 2019 spring wouldn't fit on a 2018 if I didnt want over 2 inches up front? I already have the 18 eibach springs on my 18 raptor which sits damn near level but if I install my tool box it will sit nose high by 1/4 to 1/2 inch or more depending on what's in it. This might be my solution instead of dropping 2-3k on rear icon springs and bumps. Or just suck it up save my money and get rear leafs?
The eibachs are the same part number for both the 18's and the 19's.
They likely have different results because of the shocks on the '19..
Sent from my SM-G960W using Tapatalk
@vazo is correct. Same part, different results.
@f150jack, your best bet would be Deaver +3 or possibly HD springs, or go with the Icon springs. Depends on your toolbox weight on which would be the right route for you.
Tyler_GTS
Hey Ya'll, I've got a question about the Eibach Springs instal.
I had my Ford Dealer quote me 5-7 hours and saying it would run around $600 just for the instal. That seems high, but I wanted to see what other people were paying for the install of just springs + alignment.
PCDan
Park City
Does that include the alignment ? Alignment will run you 100-$150. If it does 5 hours is probably about right.
If they have done it before it shouldn’t take them more than and a few hours per side. I could probably do it in an hour per side now if I really went fast, but I also have a lift which saves a lot of time.
Tyler_GTS
Does that include the alignment ? Alignment will run you 100-$150. Of it does 5 hours is probably about right.
That includes alignment, yea. He just said it would take all day and they've never really done this before on a Raptor. Kinda weird since they are a Ford Dealer.
They also have lifts here, so thats why the time was surprising to me. I didn't expect this to be an all day thing so if I decide the install price is fair, I can just come back later when I have a ride.
Leftsidej
Missouri
Pretty high..... my install, alignment included, was 350.
Mbdurham
Georgia
On a 19 will eibachs level it out or make it too high that the rear would need to be lifted as well?
Tyler_GTS
The Eibach's will hopefully make it more level, since I don't think they raise it as much as 17-18.
My final quote was $529 w/ alignment. Which sucks, but I'll probably be stuck with them since Im not sure of any other shops.
Heeblet
Anyone running w just Deaver +2?
Sent from my iPad using Tapatalk Pro
Carlos M
No way. I spoke with 1 store in Houston and they said 1.5-2 hours at 180 + 115 for aligment. Then check with a second shop and the said 2 hours of labor for ~$220 + alignment on my own.
Carlos M
Nick,
which springs are you referring to for the rear? I assume Icon leafs that we discussed on another thread?
