Eibach Pro-lift springs installed with pics and comments
Slow6
AK
Yeah that sounds like a logical idea. Depending on how much weight you carry full time in the bed is the only thing I can thing I can think of that would make you go to the 2nd or 3rd option with the Icons unless you like a super raked look with the Eibachs.
If I were to put Deaver +3 or Icon option 1 on as it stands now I'd be an inch taller in the rear which sounds good to me.
I carry around 400. Counting the cover. Most is in front of the wheel well. Tow occasionally. I guess I’ll make that call based on how much lift I get out of the Eibach’s
Leftsidej
Missouri
Ahhh yeah, that makes sense then. Very interested to see what ends up happening on your end after you finish the install for the front and rear.
Slow6
AK
My front is only at 39 1/2 currently. Rear is around 41.25.
My rears are being somewhat held up by the Sumo Super Spring supports right now. I refuse to remove them until my Icons come in because I know the rear springs are totally F-ed. I will remove the “Sumos” and get new measurements in the garage before I remove factory springs. All I can figure for the front being lower then most other people is that maybe when I towed my trailer I might of had the distribution hitch transferring too much weight to the front... maybe I compromised the fronts too. Yours appeared to gain less than 2 inches which has me concerned. Thinking of ordering a set of Geiser springs, I don’t want to install eibach and get less than 2 inches ride height change.
Slow6
AK
Thanks for the update @Leftsidej.
I'm really surprised you didn't get the full 2.5" which is what I am hoping doesn't happen to to mine.
Do you know what the back measured in at before the install?
Looks like your measurements before the install are very close to my '18.
Sent from my SM-G960W using Tapatalk
After all this let me know what your measurements are. I’m concerned about not getting the advertised 2.5 lift. Sounds like some aren’t even getting 2.
Tyler_GTS
As a 19' owner, I think I may prefer the (possibly lower) lift from the Eibach. Since I dont plan on doing Deavers, I think it could help with the possible Nose High look.
MZRaptor72
Cincinnati
I can tell you i just installed Geisers with Icons last week on my 19. Geisers went on first... i was definitely nose high before putting the rear icons on.
vazo
What year is your truck?
Leftsidej
Missouri
Seems like my 17 got the same outcome as what 19's are apparently getting, 1.7-1.9. My rear is stock and as it sits now my front is one inch higher than the rear. Not a fan of a cali-lean but you really can't tell... It looks leveled.
PCDan
Park City
how much
How much gas in the tank ?
