Eibach Pro-lift springs installed with pics and comments
Leftsidej
Missouri
How will I know the spring rates of the eibachs if both rates are listed as the same part number? The one sold on stage 3 is the new eibach springs with 548 spring rate?
I just bought mine today from @FordRaptorLights.com I'm assuming all retailers are the new rate because of how quickly eibach changed the rate after release due to complaints which was early-mid 2017. Surely two years later all inventory is the new 548.
Leftsidej
Missouri
Just the springs and camber bolts if you choose to get them. Make sure you give them the alignment specs from eibach too. I got camber bolts for my gen1 at sdhq.
I’m assuming the alignment specs come with the springs right? Would only makes
sense but as I’m learning a lot of mechanical items see out of wack lol
Wfo
Syracuse
Don’t remember if there were in the box. You can look them up on their website
Slow6
AK
I think I’ll have the camber bolt set up on hand, cheap insurance if needed. I’m a little further away from parts houses then you all.
Lower lock out bolts and upper A-arm will come later with a shock upgrade.
FrodoTBaggins88
US - Utah
If you order from Stage 3 they get drop-shipped direct from Eibach so they will be the newest part number. Stage 3 ran out of stock of the old part number (higher spring rate) a while back.
Slow6
AK
NeoGarage also had springs drop shipped from Eibach when I ordered mine.
