Eibach lift springs
ZaneMasterX
Mountains
New front lift option for the 2017 Raptor from Eibach with a set of lift springs. MSRP $224.10
NEW—Eibach Pro-Lift-Kit springs are designed to provide a suspension lift for your vehicle without the use of coilover systems or spacer lifts. Eibach spring lifts allow full range of suspension travel without additional stress on bushings and ball-joints as seen with spacer lift systems.
Each Pro-Lift-Kit is engineered and manufactured using the same technology found in our championship winning ERO Offroad Race Springs and carefully tested to provide unparalleled ride quality and off-road capability.
The 2017 Ford Raptor Pro-Lift-Kit raises the front suspension 2.5 inches for a level stance, increased bump travel and off-road performance capable of handling any terrain in its path.
PRO-LIFT-KIT | Performance Springs
Part Number Pricing and Data
2.5" Front Lift Springs for 2017 Ford Raptors
Manufactured using race winning off-road race spring technology
Developed specifically for the Raptor to provide balanced ride quality, control and offroad capability
Made by Eibach in the USA
PRO-LIFT-KIT # E30-35-038-01-20
2017 FORD F-150 RAPTOR PRO-LIFT-KIT DATA:
TECHNICAL INFORMATION
FRONT:
OE rate: 93 N/mm (533 lbs/in)
PRO-LIFT-KIT rate: 102 N/mm (583 lbs/in)
Bump-stop: OE
Damper: OE
Tubing: N/A
OE hub center to fender: 608 mm
PRO-LIFT-KIT hub center to fender: 672 mm
OE Camber = -0.9 -0.7deg (+/-0.1 deg)
PRO-LIFT-KIT Camber = -0.4 deg
OE Toe = 0 - 0.2 deg (+/-0.10 deg)
PRO-LIFT-KIT Toe = 0.1 deg
Approximate installation time: 2.0 hr
Link to Eibach
Bullishone
I wonder what happens when you tow. Does it really sag the rear? I love this option over the spacers.
Sent from my Nexus 6P using Tapatalk
Raptize
Damn, this is could be a real option.
2.5 inches would make the front sit up a little right, or would that be level?
Who will be first? I am waiting for my truck to arrive.
Bigoil
From the pi
From the pic it pretty level .
