egr vs avs vs weathertech window visors
Big Blue
Administrator
Staff member
Admin
USA
I have the AVS window visors. Fit great, look great, no issues. They fit over the rubber window gasket.
As far as "in-channel" visors...Good luck to you. I bought a set and they would not work on the fronts. Too tight of a fit and everytime I would try to close the window it would get caught up and lower itself...no go.
ABNRAPTOR
I had the AVS guards on for a couple years. They worked great, I just wasn't crazy about the looks. I just installed the WeatherTech guards recently. The look for me is great, but it did take a while for them to settle in properly. Roll the window up and down SLOWLY a few times and then let 'em sit for a bit. The rear guards have a little adhesive that goes up in the seal to hold them in place, but the front use a little hook on the bottom next to the A pillar (again not the best look, but not too noticeable)
The 3M tape holding the AVS's up kicked my butt since I didn't have goo gone or anything fancy like that. They were stuck on so good they broke off in pieces as I pulled them off (granted it was pretty cold here in Colorado as I did this)
There is more space and coverage from the AVS's if heaven forbid you are smoking in your Raptor, but WeatherTech give ample fresh air without a ton of noise or any wet stuff.
F
FreightTerrain
land of oz
i had avs inchannel in both my rangers with good luck but didnt have to worry about the auto features on the raptor. if i cant get the inchannel to work well ill got without.
linexsa
San Antonio TX
weathertech is all i will sell in channel. these arent my taste, but i sell alot in the store. the weathertechs are the best constructed.
