Educate me on shackles and bumps
MnFlyer
MN
Yes sir Option 1. It picked up the rear full 2" and it did saddle 0.5" i am still with empty bed 1.5" over stock and not sure if it will saddle another 0.5". Live Valves on 2019-2020 act little different then regular 3.0 on 2017-2018. We get less lift on the front with same Eibachs springs oppose to 2017-2018 and more in the rear with same setups on Icon. Have no idea why but it is what it is. Numbers that you getting for Icon Options of their website are measured on 2017-2018. Also Eibachs on 2019 and up will get you leveled with stock rear (rear actually still might be 0.5 inches higher) when you add Icons on Option 1 it will net you another 1.5" to the rear above stock like it did in my case.
Did you reset your shock height after the new springs were installed?
Wojciech Gierczynski
Illinois
Is that recommended?
You just get in your truck and without pressing on brake put ignition to ON position and then OFF Position. This resets Live Valves. Many time when lets say you changing tire on Raptor with Live Valves you will notice that after jacking up the truck your rear or front depending which tire you changing will be higher then before. Same thing simple reset as I mentioned above will correct it and Live Valves go back to normal position.
