Composite and not aluminum![]()
sounds fancy
Around here we call 'em work trucks. You wouldn't even think about fixing those kinds of things up.
I have a friend with a mint mustang except the aluminum hood is corroding bad and Ford won't fix it, wonder if this happens to the new F150.
http://www.carcomplaints.com/media/complaints/images/1efb3cc6-867a-1032-b743-4c3114d2dee3r.jpg
what do you think your raptor hood is made of
JustVettn,
This is another example of inexact science. Typical of the "Myth Busters".
To truly assess the situation, a steel quarter panel and an aluminum panel would need to be struck with the same force, as well as vector of impact. The resulting damage would then need to be assessed by several body shops. Replacement of the rear tail light would be the same in both IF necessary...in the video they struck the quarter panel twice 'because there was not enough damage from the single strike'!!!
With impacts of the exact same force in the same vector of impact only then can you speculate as to the costs.
I would bet that the costs would be much closer; only under much more stringent testing can one extrapolate fairly....
Eddie
ps the box, cab, hood, and quarter panels are aluminum...steel usage is largely in the frame, suspension, block etc.
pps Also the two body panels would have to have the same stampings ie a 2015 style quarter panel in both aluminum and one in steel...as the stampings from dissimilar years would again render the comparison invalid.
ppps In addition striking 100 steel panels and 100 aluminum panels under the same conditions sent to 100 different repair shops...now we're talking more about facts than opinions...
