Ecoboost isn't going anywhere
jaz13
The G2 axle shafted have 31 spline which I think(?) is up 1 from the previous model. As has previously been discussed --at length-- the e-locker won’t engage in 2h because this was seen as a failure point in the <cough> higher horsepower iterations of the G1 <cough> they specifically called out the supercharged 6.2 as being bit harsh on the rear end.
So yes, there’s plenty of hp potential in the eco’ but there is a weak link in every drive train. Fortunately we have beta testers like @Guy, @Bullishone, etc. exploring the tune options, more power and over time we’ll see what parts they break. Thanks guys !
OEMs design for longevity, so while the drivetrain will handle bigger HP today and tomorrow, those rear ends might not make it to 100k. The silver lining is driveshafts and differentials are a lot easier and less expensive to replace than motors and transmissions.
Jtnuge
Truckzor, I was referring to the exhaust note at the tailpipes. I have not turned off the custom noise through the speakers. I will at times turn off the music and listen to the turbo noises though. Wish those were louder.
hkguns
Most of you probably shrugged right past this as his/her normal ecoboost ************, but if you look deeper, and in light of ’77’s known mental instability, this is basically this frustrated, schizophrenic user’s initial signs of “escalation”.
They’ve failed to win any converts despite hundreds of posts that say pretty much exactly the same thing. This leads the emotionally disturbed person or EDP to try harder and harder or “escalate”. Escalation is the typical path EDP with some kind of psychiatric condition from which they initially gain satisfaction.
If you look back historically, Sasquatch77 has repeatedly said things would happen that didn’t come true. As a result, fewer and fewer FRF users even pay attention to him/her, but instead of going away, EDPs continue to up the ante.
This is one of the first visible posts exhibiting escalation and indicative of a very near future psychotic break with actual reality, that is going to result in physical harm to either the EDP or someone else.
Moderators have a ticking time bomb on their hands here with Sasquatch77, and it’s only a matter of time before it escalates into FRF user harassment, stalking or worse.
Sasquatch77, you need psychiatric help, NOW. Please get it before you harm yourself or someone else.
Naw, he's just a RAM salesman who is sick and tired of slapping $$ on the window to move inventory.
