GEN 2 Ebov tick....tick,tick
MEATSWORD
Arizona
So I have an 18SCREW and installed a AFE scorcher (the one that just piggybacks not a tuner) and after I installed it the ebov ticks at idle(could be all the time but I only hear it at low speeds) . No codes and it runs well.
Anyone else run in to this issue?
Thanks
MEATSWORD
MEATSWORD
Arizona
I've had the scorcher on for a few months until the dealership replaced the ecu (some kind of comms failure) and it ticked before and after the ecu replacement .
I haven't tried to un install it to see if the tick goes away yet.
Booth9999
Idyllwild
Next step is remove the scorcher and see if it still ticks, if so sounds like the blowoff valve is faulty take it in for warranty. Either way you’ll need to remove the scorcher. Mine definitely does not click.
MEATSWORD
MEATSWORD
Arizona
I plan to check that out today.
Clockton
Northern CA.
Thanks
I have the same issue. BOV opens and closes at idle. I haven't found a solution and not sure its a problem
does it sounds like this https://share.icloud.com/photos/0yzDvyblU_UxpdvrqsDNi5cfQ#Home
