eBay Intercooler
jgree32
FlyingRaptor
FlyingRaptor
Anymore specifics on the bracket required?
My work has milling machines etc. I could probably get whatever size I need made there.
I just cut the aluminum to the right size, marked and drilled some holes and bolted it on. Took me maybe 10 min using an angle grinder and drill. You will need a bolt and nut for the blowoff valve and the M6-1.00 bolts thread right into the intercooler.
titanjc
Lutz, FL
I might have to pull the trigger on one of these, that price is too good to pass up. Can one of you who's done the install please link what weatherstripping you went with on Amazon?
Sent from my SM-G950U using Tapatalk
Turbo 6
Louisiana
Too cheap to pass up. Especially since I’ve proven they’re Mishimoto units. Probably off spec because of the blow off valve mounting holes. Easily fixed by making your own bracket.
