Mjolnir
Did you have to remove the fender flares for the installation?
I'm soon to be adding the LCA and the 3" bypass shock.
Yes, apparently to remove the inner liner you have to pull the flares
Looks awesome, What created the increase in turn radius? The bumps just reduce the amount it turns relative to stock?
Do you expect the rear to rise slightly with the corrected leaf springs?
If it doesn't level much more will you be re-aiming your headlights?
Did they have to cut the inner wheel liner to accommodate the bypass shocks?
Looks exceptional!
