Humvee21
- Joined
- Aug 17, 2011
- Posts
- 4,848
- Reaction score
- 538
I suggest you read these threads carefully and thoroughly:
http://www.fordraptorforum.com/f11/opinions-needed-bed-protection-4045/
http://www.fordraptorforum.com/f11/bedrug-vs-bedtred-1568/
Also, since you decided to add the dealer drop in liner, I am going to assume that you are not going to be a hardcore hauler. Therefore, I would suggest either the BedRug or BedTred because not only will either product be more protective than the dealer drop in crap, but it is also not permanent (which would mean that there is basically no risk of a bad Line-X prep job).
Personally, I chose BedTred after receiving samples of both BedTred and BedRug. I then took a hammer and abused the crap out of both samples on a block of wood. Each and everytime, the BedTred showed the least amount of indentures on the block of wood. It also held up better than the BedRug because the BedRug had indentures in it that still has not come back. Another thing is that the BedRug started having small holes in it due to the square edge of the hammer.
I also liked the fact that BedTred does not soak any liquids. BedRug does not absorb liquids either, but it does allow liquids to flow through it.
I have had my BedTred for about a year and I love it. If I had to do it all over again, I would choose BedTred every single time.
