Drivers door intermittently won’t open
N8R
ontario, canada
Hello here’s my 2012 rig. Im having problems with the drivers door intermittently not opening from either the door unlock button or the key fob or key cylinder. The only way to open it is go in from the passenger side and open it from the inside and then It’s ok for a bit. I can’t figure out if the rod is binding or and issue with the latch or the actuator and unfortunately It’s intermittent and when it happens i don’t have time to diagnose the issue properly. Does anyone have any insight, thanks.
