FREEHAVOC
Confirmed steering rack is bad as well as power steering pump is going out. Also right rear shock is leaking and not covered under warranty. Purchased less than 3000 miles ago.. Beyond frustraded.
Rack and pump should be covered. Be sure that they thoroughly flush the system. Is it stock? If so, ask for them to replace the lines and the PS reservoir. Sounds extreme, but I've had four pumps go bad in two months and I'm thinking it is due to contamination in the system.Confirmed steering rack is bad as well as power steering pump is going out. Also right rear shock is leaking and not covered under warranty. Purchased less than 3000 miles ago.. Beyond frustraded.
