Driver door panel/handle squeak fix
ddpt
any ideas on how to fix the driver door panel/handle from squeaking?
My left leg rest against the door panel where the handle is positioned and causes it to squeak when resting against it.
Thought maybe some sort of lubricant spray designed for this purpose might be out there.
thanks
tc2000
Wisconsin
My new 2019 squeaks in the window switch/mirror panel area. If I press it firmly it goes away. Drives me crazy. You think lubricant spray would do the trick?
melvimbe
thanks
I've noticed the same thing. Right now, my solution is...don't do that. Will watch this thread for possible real solutions.
Gsteve
my 18 did it , the fixed it , still did it. M y 19 does it too. Every cheap f150 ive seen doesn't!
TYRCS
If you take it to the Ford dealer they have repair kit, it took me 3 oil change visits, I continued to bitch about it and they fixed it, I think they spray some foam in to the panel or something and it binds everything together since its cheap lose plastic.
raptor3757
US
Hi guys, I had the same problem on my 18 raptor.
***FIX*** I purchased a padded role with adhesive on one side, the handle pops off with flat head screw driver (see youtube video) and padded the areas under the handle.
Much better than squeaky handle.
hope that helps
