Drive without front axle
nate_13
texas
So i busted a front axle on the gen 3 and part wont be here for a week i need to drive the truck to work for oneday, flat roads no offroading so i took out the axle broke it down and re installed the outer hub to hold spindle in place i noticed it leaked out about 5-6 ounces of front diff fluid is this normal, i can see some bearings in there that look to be sealed off or is it open to the front diff? Just wanted to know if it was ok to run it for a day like this and would be traveling 150 miles round trip. Thanks!
GCATX
King Dingaling
Central Texas
Yeah, the shaft fits into the seal to keep diff fluid from spilling out. I wouldn't drive it, or maybe tape up the hole and pull the front drive shaft in case it starts spinning.
No.
Ok only to get you home while you are off road; field expedient repair. Get you back to civilization and that’s it.
I got grounded one time at a Ducati stealership. the conversation went like this
service mgr. “Look, Smurf, got some good news and some bad news. We got your service done, but we can’t let you ride the bike. There’s a safety recall on the fuel system. hose from the fuel pump can come loose. We have to inspect, replace any defective parts. your bike has one of the defective clamps and could come loose”.
me: Can’t I just ride home, bring it back when you have the part handy?
( as soon as I got the sentence out, I knew how stupid it sounded in context, but, before I could speak )
service mgr: “Smurf, the bike could literally, spontaneously combust. With you on it. No."
You’re grounded. Be patient, don’t be foolish.
figure1a
San Diego
Odd question, but are you out of warranty already? Why isn't Ford working on this? They should fix that if you are under warranty even if it broke while heavy off roading (unless you have physical impact damage evident).
N
nate_13
texas
Thanks! And yeah its leaking from front diff hole i thought it was completely sealed off but apparently not guess the shaft makes a seal and doesnt let fluid roll out i stuff a rag in there for now.
Donovan
DC
Boy oh Boy.
Who needs that front axle, am I right? And yeah, isnt this under warranty?
