Once the bolt has been installed from the factory it has been stretched and should never be reused... After it has been stretched it is junk... This is a +50k truck and its a important part of the vehicle... If you do a mod on something as important the suspension why wouldnt you spend a bit more and replace the bolt so its done right?
SVT Raptor
Install the shock absorber and spring assembly lower spacer and a new lock washer.
All vehicles
NOTE: Do not tighten the nut at this time.
Position the shock absorber and loosely install the new shock absorber lower nut and bolt.
Connect the upper arm ball joint to the wheel knuckle and install the new nut.
Tighten to 115 Nm (85 lb-ft).
Install the new tie-rod end nut.
SVT Raptor
Install the wheel bearing and wheel hub. For additional information, refer to Wheel Bearing and Wheel Hub in this section.
All vehicles
Install the wheel and tire. For additional information, refer to Section 204-04 .
Install the new shock absorber upper mount nuts.
Tighten to 40 Nm (30 lb-ft).
With the weight of the vehicle on the wheel and tire, tighten the shock absorber lower nut to 550 Nm (406 lb-ft).
