Door started squeeking
Raptor_man
Michigan *******
My driver side door started squeaking when I open and close it. It's not coming from the door dent location. I think its coming from the linkage up top.
I tried tightening the bolts a bit - but they were already pretty tight and it didn't eliminate the sound. My truck has 11,000 miles on it and it just started squeaking.
Marcs
US
Just started doing the same thing on mine....lubed everything....still have issue.....
Pynenut
Las Vegas, NV
Me 3. Don't ya love it. Subd for a solution...might just spray everything down with seafoam deepcreep
mike.s
Well-Known Member
I get squeaking on both driver and passenger side doors. In my case it comes from the rubber weather seal near the side mirrors. It gets folded in a certain way that causes the squeaking. I can fix it temporarily but it always come back. I've learned to live with it.
Huck
Chicago Sw Burbs
Same here. Its the weather stripping seal on the top by the mirror. I unfold mine and put some silicon on it, last for a week or so and starts to squeak again.
FordService
My driver side door started squeaking when I open and close it...
I get squeaking on both driver and passenger side doors...
Same here...
Hi gang,
If you're still getting a noise even after a few DIY approaches, you may want to bring this up to your dealership so they can check that out. As always, I'll be around in case you need my help. :)
Crystal
mike.s
Well-Known Member
The squeaking has gone away by itself in my truck. It wouldn't be surprised if it came back though
cayenne
Windsor, CO
Same here. Really bad in the winter when it's cold!
