Do Deavers Settle???
LekRap
Corona, CA
Hi,
I am very close to purchasing some Deaver leafs. I have been seeing and hearing different things about them settling over time.
Some say they don't settle at all
Some say they settle 3/4"
Some say they have settled a couple inches
Just curious what peoples individual experiences have been with them. I am leaning towards getting +2's...not sure if that matters for settling compared to +3's or +1's but would interested in any and all feedback. Thanks!
Labraptor
Illinois
Most have had little settling. Mine settled a lot. About 3" in a month.
They are +3 by the way.
Labraptor
Illinois
Roger that Joe. I did before ARDD, had someone else check them earlier this week and if I get time I will check them Monday as well.
LekRap
LekRap
Corona, CA
Thanks @Labraptor and @Huck. Does anyone know If there is a standard of how much they settle? Do most settle 3/4" or most don't really settle at all?
I'd imagine that the more real off-road in that you do, the more likely they are to settle/sag...right?
Huck
Chicago Sw Burbs
Everything with settle, even coil springs settle. There's no direct formula for how much they will settle or sag for that matter.
MTF
Celebration, Florida
3" !!! Do you know what the measurements were from ground to fender flare when you torque all the bolts while all the weight was on them?
Are you using a drop shackle?
3" on +3 settling means you're now at 42 to 42 1/2" from ground to rear fender flare, right?
Huck
Chicago Sw Burbs
No drop shackles all stock. It started really high.
LekRap
LekRap
Corona, CA
I'm glad that I live within 30 minutes of Deavers headquarters, can always bring them back if any issues like Labraptor had. So if @Labraptor started really high, how high was his to start with? @Huck you said that you had issues with National Leafs sagging like this. Is this just something that could happen if you are hard enough on them?
